94 accord ex d4 light will not come on
My d4 light has went out for some reason, does anyone know how to fix this , is it a fuse some where or what, it will not come on at all
Korean Member
If so burn out bulb could be your problem.
Originally Posted by AccordManiac
Are you talking about D4 light from the cluster?
a) Honda Dealership don't sell just the LED bulb needed for the replacement and will only sell you the cluster (which will be costly).
b) Automotive shops won't carry the correct LED bulb size you need.
When I needed to replace the bulb in my hazard light switch and climate control LED, I was only given the option of buying the a new hazard light switch and a new climate control cluster. Honda for some reason does not have a part number for the bulb/LED but will have one for the whole unit. I'm not sure if Honda did it on purpose or the dealer trying to rip me off, but... told the dealer to screw it and found the parts at a local junkyard. You may need to do this.
