Oil level weirdness
Old Jul 4, 2006 | 06:33 AM
gradas's Avatar
gradas
Default Oil level weirdness
I have an ongoing oil consumption problem in my 99 Accord (4 cyl). The car has 88k miles.
Yesterday I checked oil after the car was parked for about an hour (on a very hot day) and the level was below the lower mark. This morning I checked it again (the car was parked overnight, so the engine was completely cold) and the level was almost at the full mark, about 90% full. How is this possible???
There are no drip or leak marks under the engine or in the engine bay, last oil change dealer could not locate any leaks (oil pan seals, etc), so they asked me to start recording oil levels when I fill up gas. No signs of coolant in the oil or vice versa.
Any explanations for such fluctuation in oil levels? You would think that warm engine would show a higher level than cold engine.
Old Jul 4, 2006 | 06:57 AM
JimBlake's Avatar
JimBlake
It'll be sensitive to how level the parking spot is. The dipstick is all the way on one side of the pan. Can you park always in the same spot?
It'll be sensitive to how long since you shut off the engine. Not only the temperature but how much time the oil has to drain down from the head & everywhere else. Try to be as consistant as possible when you're recording oil levels. Maybe record oil level in the morning instead of at all the different gas stations.
Old Jul 4, 2006 | 07:52 AM
Shallow_Bay's Avatar
Shallow_Bay
teh accord guy
Plus, don't forget, all that oil that runs through the whole engine, does take a while to drop back down to the pan
Old Jul 4, 2006 | 07:55 AM
gradas's Avatar
gradas
I would think an hour would be enough time for hot oil to come down. Does it take longer?
Old Jul 4, 2006 | 11:43 AM
JimBlake's Avatar
JimBlake
There's lots of places in the head for oil to puddle. But it seems like an hour is long enough. ???
Maybe the biggest reasons for the variation is oil temperature & levelness of the parking spot. It can take several hours for the engine to really cool down. Levelness side-to-side might be the biggest thing. Get your right-side wheels down (highly crowned street?) and it'll measure low because all the oil runs away from the dipstick.
Old Jul 4, 2006 | 12:16 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
This is why we test oil level 5 minutes after the car has been warmed and shut off, just like the owner's manual says.
Old Jul 5, 2006 | 10:47 AM
george3045@bell's Avatar
george3045@bell
georgeda
I check my oil with the car in the garage after it has been sitting at least a day.
Old Jul 5, 2006 | 11:02 AM
98CoupeV6's Avatar
98CoupeV6
that's very wrong.
Old Jul 5, 2006 | 02:01 PM
Cousin It's Avatar
Cousin It
I used to have a POS Ford (which is why I now have a Honda) that did the same thing. Turned out the oil return holes were clogged and it took forever for the oil to drain back to the pan. Not sure if your Honda has a similar design/problem. Just a guess.
Old Jul 5, 2006 | 05:27 PM
JimBlake's Avatar
JimBlake
Originally Posted by 98CoupeV6
that's very wrong.
OK, but it's consistant. So why should the level keep changing?
