Huge Problem...need Help!!!!
Old Jun 20, 2006 | 02:30 PM
BigVic4545's Avatar
BigVic4545
Default Huge Problem...need Help!!!!
Ok guys i have a 94 accord ex 4 door..The problem is that my key wont come out of the switch. Ok...You kno how you have to turn ur key 3 times or so before you actually turn it to start it....well it turns all the way back to the second turn but is stuck there....i tried experimenting and disconnected the battery and the key comes out fine...but when the battery was recconected it was stuck on the same spot...guys i really need help because i have to leave the key in the car overnight and it drains my battery in the morning.
Old Jun 20, 2006 | 09:13 PM
Illicit Accord's Avatar
Illicit Accord
is the car an auto??
Old Jun 21, 2006 | 05:10 AM
fstop128's Avatar
fstop128
replace the ignition switch.
Old Jun 21, 2006 | 12:32 PM
BigVic4545's Avatar
BigVic4545
Yea its an automatic
Old Jun 21, 2006 | 01:58 PM
luckybays's Avatar
luckybays
same problem on the 93 accord once. try putting some oil on the key, insert it into the key hole and turn it back and forth a few time; try it a few more time to keep it well lubricated. if it does get stuck, turn the steering wheel back and forth and the key should come off.
Old Jun 21, 2006 | 03:07 PM
stereo's Avatar
stereo
is the P on the dash lit ? try disconnectiong the battery if you can remove the key now then theres a problem with the interlock.
Old Jun 21, 2006 | 05:36 PM
BigVic4545's Avatar
BigVic4545
Yup the P is light up...im pretty sure it has to do with the interlock...because when i disconnect the battery it comes out fine....so what exactly is the interlock and how can i solve this problem???/
Old Jul 3, 2006 | 07:14 PM
BigVic4545's Avatar
BigVic4545
Im still stuck....i need help!!!
Old Jul 3, 2006 | 09:08 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
This happened in my civic dont know if it will help, I rocked the car back and forth. Hard to explain, I just go to the back bumper push the car forward and let it rock back then push forward again do that 4x 5x then try to remove the key. I think it has something to do with the car not in P all the way when you turned off the car.
Old Jul 3, 2006 | 09:48 PM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
do you have an aftermarket knob? if so then thats your problem...i have one my 98 accord v6 and if its skrewed on too tight it'll compress and the car thinks your pressin down on the knob so the key won't come out....if you losen it up, key pops right out.........IF you don't have an aftermarket knob thennnnnnnnn i dunno check your ignition switch
