Experiencing a Humming sound?
Old Jun 19, 2006 | 08:19 PM
blindmokey13's Avatar
blindmokey13
I appreciate the help 98 i had my brakes and rotors done, and i'm going to try and see what i can do about the humming and my main relay when i can. Much appreciated.
Old Jun 19, 2006 | 08:33 PM
90CvcDX's Avatar
90CvcDX
kekeke
wheel bearing, i have the same issue with my driver's side one. you should replace both either way. if you can get the whole assembly apart yourself it should be no more then like $60 depending on where you take it.
Old Jun 19, 2006 | 11:21 PM
CaliAccord's Avatar
CaliAccord
Sounds just like the sound my accord made when the bearing went bad on the passenger's side.
And yes, I agree that the 2nd problem is due to the main relay
