Bolt pattern & backspacing for 2003 Accord?
Old Jun 4, 2006 | 04:18 PM
LocoLT1's Avatar
LocoLT1
Default Bolt pattern & backspacing for 2003 Accord?
What's the bolt pattern on a 2003 Accord?
What backspacing should I be looking for in a 17" wheel? I'd like to keep it in the stock location. I don't want it sticking out looking stupid etc.
Old Jun 5, 2006 | 05:05 PM
LocoLT1's Avatar
LocoLT1
No one knows the stock offset or what offset would keep a 17x7 wheel in the same spot?
Old Jun 5, 2006 | 06:20 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
5-114.3, (5x4.5") our TSX is a +55mm offset and since the '06 uses the TL-S rim on the 6-speed I know that was a+55mm rim. So I think it would be safe to assume the Accord is also a +55mm offset.
However, the TL for '04+ is a +45mm if I recall, but the Accord is likely +55mm since it and the TSX share the same optional rims...
Old Jun 6, 2006 | 09:11 AM
Vlad666's Avatar
Vlad666
Here you go....bolt patterns, offsets and more, for practically every brand of vehicle. Just scroll down to Honda portion.
http://www.fastco.ca/web-content/Ima...06appguide.pdf
Old Jun 6, 2006 | 04:14 PM
MrChad's Avatar
MrChad
That chart is wrong BTW.
The 98-00 (01-02) Accord 4cyl is +55mm offset. I know, I own the rims, they came with the car when I purchase it new in March of '00.
Old Jun 7, 2006 | 06:30 AM
Vlad666's Avatar
Vlad666
MrChad
Could it be you have rims for V6 model. Those came with +55 offset. The reason for me saying this is that I have 2003 Accord I4 with V6 model front calipers. For the love of god I have no idea why, but I had to bring my old pads to the KVR Performance store, when the ones made for my model would not fit.
Cheers
Old Jun 7, 2006 | 07:15 AM
buffalobill's Avatar
buffalobill
Here's a couple of helpful tire & wheel size calculators; plus they graphically & numerically display what happens to the wheel/tire location within a wheel well when either a wheel's width and/or offset is changed:
rims-n-tires.com/info_specs.jsp
1010tires.com/WheelOffsetCalculator.asp
Old Jun 7, 2006 | 03:09 PM
MrChad's Avatar
MrChad
Originally Posted by Vlad666
MrChad
Cheers
Umm...not unless they magically started making a 4 bolt V6 rim in 98-00...
All 6th gen v6 cars are 5 lug, I4 is a 4 lug. Can't put a 4 lug on a 5 lug car...
Trust me I had to argue this out with a rim mfg. once. The i-4 gen 6 Accord's are unique in that they have a +55 offset rim just like the v6.
Anyone with a 6th gen 4cyl with Alloys can check, the rim will read 15 J6 +55 on the rear.
I think if check with Jschmid he will confirm that some of the 2.3 CL's also had a +55 4 lug in '99.
My rims are the standard EX coupe rim from '00, only about 30,000+ coupes in '00 have this exact rim so it's fairly rare (sarcasm). My rim was in production from 1998-00...
