light NOT on....
Old May 31, 2006 | 02:47 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Search "clock bulb" or some other variation and you WILL be rewarded.
Old May 31, 2006 | 02:52 PM
Misa's Avatar
Misa
Pic Whore
new threads should be moderated in this forum before they are posted
clock lights up while car is running... if its not, replace the bulb. do a search for instructions.
:closed:
Old May 31, 2006 | 03:48 PM
jschmid's Avatar
jschmid
There is a bulb, and just because it doesn't come on doesn't automatically mean it's burned out. If you do a search on here you'll find that it's a common problem and very often it's not the bulb...it's a short of somekind.
Over the past 6 years my clock light has come on and off whenever it feels like it. Never changed the bulb, every once in a while it decides to come on.
Old May 31, 2006 | 07:22 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
Mine did this as well for along time, but I replaced the bulb for fun and the problem went away...
..I've had the same issue with the cruise control bulb and the sunroof bulb too. The bulbs are cheap and they go easy...
Lucky for us they run only a few bucks and can be changed in minutes.
Old Jun 1, 2006 | 08:46 AM
jerry00's Avatar
jerry00
hm...if there is a bulb i'll try chaning it. i was confused because my '95 civic has a lit up clock and my '02 accord doesn't.
Old Jun 2, 2006 | 08:46 AM
jschmid's Avatar
jschmid
I might have to try changing it out and see if that takes care of it. I bought one years ago but never installed it because the original came back on the next day.
Old Jun 5, 2006 | 06:08 PM
Honura_Kit's Avatar
Honura_Kit
yep this is a common problem. mine too
