Drivers Side Mirror Motor
Old May 15, 2006 | 06:09 AM
01ACCORD's Avatar
01ACCORD
Default Drivers Side Mirror Motor
Anyone ever replaced this?
My has been flakey for about a year. It will move up-down but not in-out,
but if I manually rotate the mirror in the housing it will sometimes work.
I'm selling this to a friend and want it fixed. Does the glass just pop off
so I can access the motor? I'm going to see if maybe some cleaning will fix
it.
Old May 15, 2006 | 02:05 PM
fstop128's Avatar
fstop128
the motor isnt in the mirror so the glass doesnt just pop off. remove the door panel and go from there. u can get parts at www.hondaautoparts.com majestic honda will come up.
Old May 15, 2006 | 02:14 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Yes, the mirror does just pop off. Hold a screwdriver to the bottom and gently pry.
Old May 15, 2006 | 02:52 PM
01ACCORD's Avatar
01ACCORD
I was able to pop it off. Better to just move it full in or out, and reach your fingers behind it and pop it off. I removed the wires and replaced and it's working fine. The motor is inside the mirror. There are two nipples that screw in and out. I snapped it back on, and all is well
Old May 15, 2006 | 03:04 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
I think this only holds true for the Sedan, the coupe uses a different motor setup but I'm glad all is well
Old May 15, 2006 | 03:40 PM
98CoupeV6's Avatar
98CoupeV6
Check the Helms.
Old May 15, 2006 | 06:22 PM
MrChad's Avatar
MrChad
Originally Posted by 98CoupeV6
Check the Helms.
I did my helms has a different motor setup for coupe vs. sedan....
Old May 15, 2006 | 06:24 PM
98CoupeV6's Avatar
98CoupeV6
So how does the Coupe mirror come off?
Old May 15, 2006 | 06:29 PM
MrChad's Avatar
MrChad
I didn't check, but it's motor is unique to the sedan. You can't manually adjust the coupe mirrors as you can on the sedan.
One uses a spring clip the other uses suctioners for lack of a better term...
