91 Accord not starting
Old May 10, 2006 | 05:30 PM
93Cobra's Avatar
93Cobra
Default 91 Accord not starting
Newbie here.
I bought a 91 Accord that wouldn't start. Replaced the main relay and it started right up. I have put around 300 miles on it and now it has the same problem. I pulled up to a stop sign and it died. It will turn over but not start. I let it sit a couple of hours and went back with the same results. I can turn the key to the on position and I hear the fuel pump and I can hear the main relay "click". When I got out I could smell the gas. Any suggestions? Thanks
Robert Jackson
Old May 11, 2006 | 03:53 PM
93Cobra's Avatar
93Cobra
Ttt
Old May 11, 2006 | 04:50 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Need more info and/or testing on your part. Is gas getting there, is there spark, etc.
Old May 11, 2006 | 05:22 PM
93Cobra's Avatar
93Cobra
Fuel is getting to the engine. I have not tested to see about spark yet. I just found some information that I am reading up on concerning spark. What is the "ignitor". Sorry about the ignorance but I have only dealt with domestic V8's. Thanks
Old May 12, 2006 | 12:43 PM
wedley2's Avatar
wedley2
bboy Wesley West
the ignitor is located within the distributor.
sorry i dont know what it is...only where it's at
Old May 12, 2006 | 02:32 PM
93Cobra's Avatar
93Cobra
I didn't get any spark at the plugs. I assume it is the ignitor or coil. The distributor was put on the day before I bought the car. Thanks for pointing out where the ignitor was
Old May 12, 2006 | 06:13 PM
98CoupeV6's Avatar
98CoupeV6
Check the easy and cheap first dude, like fuses/relays and loose connections
Old May 12, 2006 | 06:54 PM
93Cobra's Avatar
93Cobra
I checked all the fuses already and they were good to go. What relays should I check? I replaced the main relay only 300 miles ago, are there others I should check? Thanks
Robert
Old May 13, 2006 | 12:55 PM
93Cobra's Avatar
93Cobra
Well went and looked at the car again. The distributer, ignitor, and coil are all brand new. I confirmed that with the person I bought the car from. So now I am looking at the main relay again. However, it only has three hundred miles on it and it has not been that hot out. I realize that even new parts can be bad. Any thoughts? Thanks
Robert
