speedometer problem
Old May 4, 2006 | 08:09 AM
Fireball's Avatar
Fireball
Default speedometer problem
Hi,
The speedometer in my Honda Accord '96 LX stopped at 20mph and does not move. It goes to 0mph once I stop the car. How can I fix it?
Thanks
Old May 23, 2006 | 06:32 AM
flyerhky11's Avatar
flyerhky11
I have that same exact problem, any help?
Old May 23, 2006 | 06:43 AM
fstop128's Avatar
fstop128
if u have the original gauge cluster, change your vehicle speed sensor. if that doesnt solve it, its the cluster.
Old May 23, 2006 | 07:09 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Don't 5th gens use a mechanical cable for the speedometer?
Old May 23, 2006 | 07:21 AM
strykernyc's Avatar
strykernyc
yup what he said. maybe is lose.
Old May 23, 2006 | 10:39 AM
flyerhky11's Avatar
flyerhky11
I changed the VSS first, and nothing. Got a new speedo and put in my cluster and the needle jumps to 20mph when car is running but doesn't move. Put in whole new cluster and still nothing. Maybe a new VSS plug? Where is cheapest to buy VSS online?
Old May 31, 2006 | 06:50 AM
flyerhky11's Avatar
flyerhky11
So I put the new VSS in yesterday and the speedometer worked again. Only problem is that the speedo starts to read at 20mph. works fine, just thinks 20 is 0 mph. Anyone know how to resinc the speedo?
Old May 31, 2006 | 08:48 AM
stereo's Avatar
stereo
the speedo should work fine out of the box if not it might be defective or you might have overtightened the screws
Old Jun 1, 2006 | 06:35 AM
flyerhky11's Avatar
flyerhky11
I also noticed that after driving a trip that is 160 miles, the odometer only registered 58. Could this be caused by the screws being to tight? The speedometer did bounce once and a while, and clearly was giving the wrong speed.
