90 Accord Engine Problem
Old Apr 16, 2006 | 07:26 PM
flin1981's Avatar
flin1981
Default 90 Accord Engine Problem
I have this 90 accord for almost 2 years. As it reached its 200k, an engine problem came out, and more frequently lately. After running for a few minutes from cold, the engine hesitates when I step the throttle half-way. It's fine if I only press a little bit, or I step all the way down to the floor, in which case it will gain power suddenly. After a little moment, the problem would be gone.
Anyone can help me with this? Thanks a lot.
Old Apr 17, 2006 | 11:50 PM
wedley2's Avatar
wedley2
bboy Wesley West
have you done valve adjustments? (random question)
Old Apr 18, 2006 | 12:07 PM
flin1981's Avatar
flin1981
No. I have never done anything to the engine, except changing oil and oil filter.
Old Apr 18, 2006 | 12:41 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Egr.
Old Apr 19, 2006 | 02:44 PM
flin1981's Avatar
flin1981
Thanks.
But it could be the valve, or the ECU, or other wire problem. Can you tell from the symptom? It only last for a little while.
Originally Posted by 98CoupeV6
Egr.
Old Apr 19, 2006 | 03:00 PM
98CoupeV6's Avatar
98CoupeV6
Originally Posted by flin1981
Thanks.
Okay, but it could also be the EGR, which is free to clean.
Old Apr 19, 2006 | 07:55 PM
flin1981's Avatar
flin1981
Free? You mean DIY?
But how?
Old Apr 20, 2006 | 08:49 AM
98CoupeV6's Avatar
98CoupeV6
Free? You mean DIY?
But how?
By using the search button.
Old Apr 20, 2006 | 08:53 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
^^^:reechy: Try cleaning the EGR first and see if that helps...then get a tune up.
Old Apr 20, 2006 | 09:04 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Getting a new car with less than a million miles is also an option.
