Need to reset SRS light on 2000 Accord
Old Oct 10, 2012 | 05:53 AM
quigs's Avatar
quigs
I have a 2000 Accord LX and it is very important to know on this model and year that there are TWO yellow plugs up underneath right next to each other. The one plug is in the direction of the steering column and the other, right next to it, is in the direction of the fuse box. I used Azndudes method using a 3 foot piece of speaker wire instead of using a paper clip cause I found it to be a lot easier. I labored for WAY too long though because at first I WAS WORKING WITH THE WRONG YELLOW PLUG!!! Luckily I didnt f*** anything up but my point is that the correct yellow plug to use is the yellow plug that is closest to the fuse box and/or right behind the fuse box and it's the smaller yellow plug of the two yellow plugs. When I finally did use the correct plug azndudes method worked like a charm. Thanks dude...
