electrical problem!!! 90 accord
Old Mar 22, 2006 | 04:07 PM
accordh22swap's Avatar
accordh22swap
Default electrical problem!!! 90 accord
i was simply changing a bulb in my projectors.it looked fined. i changed a fuse so my emergency lights could work cuz they wouldn't. fine it was fixed. then i change a good bulb for a new one while i was at it and nothing. didn't work. i put the old one back. nothing. i check the bulbs elsewhere and they are good. i start to think when i notice that the middle bulb on both projectors now do not work, my dashboard does not light up(turning signals do but no light) and by brake lights are not on. only turn on when i press the pedal. all fuses are good? any ideas or should i just take it to an electrision?
Old Mar 22, 2006 | 07:25 PM
g1teglover's Avatar
g1teglover
i'm working on a friends accord and am having the same issue with the brake lights, except now after changing one light that was actually blown, the only the left side lights up when the brake pedal is pressed and none of them light up when the parking/headlights are on.
