99 Accord LX - Engine Replacement
Old Mar 22, 2006 | 03:38 PM
Ryleeryno's Avatar
Ryleeryno
Default 99 Accord LX - Engine Replacement
I'm replacing my 180k engine with a 28k junkyard motor. VTEC w/o ULEV, wiring harness intact paired with a 5spd tranny.
1. Any experience in this swap? Tips, etc.???
2. While I'm in there, anything else I should be looking to replace.
Thanks!
Old Mar 22, 2006 | 03:41 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
What happened to your old motor?
Old Mar 22, 2006 | 03:48 PM
Ryleeryno's Avatar
Ryleeryno
Cylinder #2 failure. No compression and no combustion. Burned oil for 1 year until it finally died last week. I've been planning on this for months. My assumption is either bad rings or dead piston.
Old Mar 22, 2006 | 04:45 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
If you don't have one, look at getting a www.helminc.com book for your Honda, it should detail all the tid bits you'll need.
Old Mar 22, 2006 | 05:30 PM
98CoupeV6's Avatar
98CoupeV6
Wow, how did that happen? 180k seems really short for an F23
Old Mar 22, 2006 | 07:00 PM
ItsaHonda's Avatar
ItsaHonda
Wow, how did that happen? 180k seems really short for an F23>>>
I'm curious also, the F-series engines are generally good for a good 250-300,000 miles before they get tired...
Old Mar 22, 2006 | 09:54 PM
skabone69's Avatar
skabone69
I recently had to replace my f23, pretty much the same thing but it was cylinder #1 that went bad. The junkyard I got my engine from said to validate the warranty I had to get a new timing belt, water pump, gaskets, seals, thermostat, new plugs, wires. the new engine runs so much better than the my old engine even before the piston rings went on cyl#1. I got a 19K engine for $500, definatly worth the money.
Old Mar 23, 2006 | 08:45 AM
Ryleeryno's Avatar
Ryleeryno
I got the car in 2002 with 38k. At around 45k I noticed that the dipstick would pop up every once in a while. BLOWBY! Well, I used 10w30 w/ frequent oil changes. 95% highway miles later I noticed very high oil consumption.
I'm going to take apart the engine after I swap it. I'll let ya'll know what's up.
Old Mar 23, 2006 | 09:08 AM
98CoupeV6's Avatar
98CoupeV6
Holy shit, the first owner must have run the piss out of it and never changed the oil.
Let me know if you need any diagrams or info to help you out, I have sitewide access to alldata through work.
Old Mar 23, 2006 | 09:12 AM
Ryleeryno's Avatar
Ryleeryno
Yeah. It was a rental car. I got it real cheap. I mean, 180k on original clutch with no slipage. Not other major issues.
The only problem I think I'll have is with the wiring harness and the frozen fuel line. PB BLASTER!!! Thanks for the help.
