OXygen SenSor Question??!!!!!!
Old Mar 19, 2006 | 12:00 PM
BigVic4545's Avatar
BigVic4545
Default OXygen SenSor Question??!!!!!!
What Up Guys..well i took my 94 accord ex (4door) to my local inspection station, and i failed The Emissions...they told me that i failed because i have no Oxygen sensor...i have a ciouple questions...
1.How much would it cost for one?
2.where the hell is the oxygen sensor located?
3.Does the oxygen sensor have nything to do with the Fuel gauge..because my fuel gauge needle always stays at teh same spot.
Thanks for ur help..i aprreciate it
Old Mar 19, 2006 | 12:54 PM
usdm-in-uk's Avatar
usdm-in-uk
hi there,i had the same problem,ok..
1,price will be between 60 & 120 bucks
2,your sensor will be b4 your cat/converter on a little bit of pipe with 2 flange conectors on(1 end to your down pipe and 1 to the cat),it will be on top,also,they are a pain to get off,& have you had your ecl on,cause this will be on if you dont have a oxy sensor in,
3,i doubt very much this will have anything to do with your fuel gauge readings,
hope this helps.. :hi5: :hi5:
Old Mar 20, 2006 | 02:49 AM
Kai's Avatar
Kai
Rotorphile.
No.
