How much oil?
Old Mar 9, 2006 | 06:52 PM
wedley2's Avatar
wedley2
bboy Wesley West
5 bottles?
mines 3.9
Old Mar 10, 2006 | 09:14 AM
strykernyc's Avatar
strykernyc
3.9 good joke
Old Mar 10, 2006 | 10:03 AM
AcuraFanatic's Avatar
AcuraFanatic
Originally Posted by humblehyper
I just changed my oil and poured 4.5 quarts, now how do I know if its really enough? I have a 2000 honda accord LX, my brother in law who drained the oil used a pressurized air to somehow remove much oil as possible.
When the engine is cold (like when its parked overnight) should the reading on the dipstick be between the lower and upper mark? Thanks much.
There's always two sides of this arguement, whether you should measure cold or hot.
When the car is hot the oil is thinner, and there will be oil in the head versus cold where it is thicker and it's all sitting in the bottom of the crankcase. I really have no preference and just compensate in my head for any inaccurate readings.
The dipstick really is a terrible measurement for oil in the engine but until they come up with something better we're pretty much stuck with it.
As far as draining the oil, I'll usually just let it drain and go watch TV or eat lunch or something and come back.
You can pour 4.5 quarts in, let the car run for 10 seconds, then check the oil level again. If the engine is hot, that's probably as accurate of a reading as you'll get from a dipstick.
Old Mar 10, 2006 | 11:43 AM
humblehyper's Avatar
humblehyper
So if the engine is hot, what should be the reading on the dipstick? Should it be just about 5mm above the lower mark? Thanks again.
Old Mar 10, 2006 | 11:53 AM
strykernyc's Avatar
strykernyc
dude is 5 "five" thats it. winter even if is -30f outside it is 5 and if is summer even if is 1000F outside it is 5.
Old Mar 10, 2006 | 12:26 PM
humblehyper
OK thanks, so I need to add another half quart
