93 Accord Using Oil
Old Feb 17, 2006 | 09:35 AM
texaskreek06's Avatar
texaskreek06
Default 93 Accord Using Oil
I changed my oil in the fall of last year and put in a synthetic that was suppose to last to 10,000 miles I believe or 1 year, but I checked it the other day and to my suprise I was halfway between the empty mark and the low mark. The engine is clean except from around the top, i think its leakign alittle around the top, but definitly not that much. Is it uncommon for a 93 Accord EX with 125k to use that much oil? Is that a bad thing?
Old Feb 17, 2006 | 10:10 AM
vtecaccord01's Avatar
vtecaccord01
Performance isn't $$$
I couldn't even tell you because I change my oil every 3000-4000 miles. Even if they said it could last that long I don't let it.
Old Feb 17, 2006 | 11:38 AM
VPUPPY's Avatar
VPUPPY
Engines usually consume a bit of oil. Have you always been using synthetic oil? If not, how many miles were on your car when you switched?
Old Feb 19, 2006 | 01:54 PM
texaskreek06
VPUPPY,
No, i bought the car about a year ago and it had been changed requarly with the normal motor oil, i bought it and it was almost due so i put synthetic in it.
Old Feb 19, 2006 | 05:54 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Did you notice there have been 2-3 threads similiar to yours created in the last week that have extensive answers in them? And yes it's normal for cars to burn oil as they age.
Old Feb 19, 2006 | 07:40 PM
wedley2's Avatar
wedley2
bboy Wesley West
i though tit was 1 quart per 1k miles?
oh and i wouldnt put synthetic...just keep to the dino oil
Old Feb 20, 2006 | 05:54 AM
98CoupeV6's Avatar
98CoupeV6
Synthetic is a good way to stop oil leaking past seals as long as you don't go back to dino after you use it.
I dunno what the service spec is. I know Porsche 944 Turbos are spec'd at 1 quart for every 600 miles...which is crazy. I used to burn a quart every 1-1.5k miles before I switched to synthetic. With Mobil1 I'm at 1 quart every 8-10k miles.
