2003 accord head light flickering
Old Feb 11, 2006 | 09:27 AM
scubaman44's Avatar
scubaman44
Default 2003 accord head light flickering
For all those with this problem, there is a service new bulletin just out:
HONDA SERVICE BULLENTIN 05-034 Dec 14, 2005
Symptom: The headlight dim with the engine running and the headlights, or DTC P 1298 {electronic load detector (ELD) circuit high voltage} is stored in the ECM/PCM.
Hope this helps someone out there. I have two 03 Honda Accords, one a coupe and the other a 4 door sedan. Both have the same problems and the dealer has the part on order. Will let you know the results.
