front end noise
Old Feb 6, 2006 | 03:27 PM
ajth87's Avatar
ajth87
Default front end noise
i have a 91 accord and there is noise coming from the front end. when i take a sharp turn, i hear a clicking noise in the front end. also when i turn at the same time going over a little bump i hear like a loud clunk noise from the front end. can anyone give me any hints as to what that is?
Old Feb 6, 2006 | 03:38 PM
busted CV joint ... get it looked at asap. Freezing water can cause wheel seperation.
Old Feb 6, 2006 | 07:05 PM
waaBAAH's Avatar
waaBAAH
agreed....look under your car at the cv boot. which one(s) is ripped/torn open. replace the whole axle. proably 130+ if shop does it...or 50 bucks if you do it.
Old Feb 10, 2006 | 02:34 PM
VtecRacer's Avatar
VtecRacer
I think i may have encountered the same problem
Mechanic said both my CV boots are shot, and I should change the driveshaft.. he said the boots have been busted for a while now.. so to be sure the driveshaft was not effected i should replace it.
OR
I could just replace the boots.. I'm not sure what to do yet.. I think the CV boots have been busted for a few weeks now.. could the driveshaft be gone too?
Old Feb 10, 2006 | 09:05 PM
waaBAAH's Avatar
waaBAAH
you have to replace the axle/shaft/halfshaft (whatever you want to call the whole assembly). the joint is already contaminated.
