Changing sensitivity on Python 1500 ESP
Does anyone know how I can change the sensitivity on my python alarm? The alarm itself comes with instructions but does not tell how to change the sensitivity and other options. Thanks
find the shock sensor and turn the knob to the left on it or actually in it. the shock sensor should be seperate from the alarm but still attached by a plug. dependind on which model u have it might just be knob on the brain and not seperat at all
yeah u can, u have to program it with the vale switch. the maanual tells u that . key in th on position, select the correct zone with the valley. if it is zone 4 u want press the valle switch 4 times and then hold it in a fitth and dont let go, then use the key pad to select feature 1 or 2 ( lock and unlock). the manual tells u exactly what zone is which. if all fails go to a circuitcity and most likely u gotta pay, the'll use the bitwriter to program it.
