idle fluctuating brings more problems...
Old Jan 17, 2006 | 11:46 PM
94ccordEx's Avatar
94ccordEx
Default idle fluctuating brings more problems...
ok first my radio and clock goes out, then my idle begins to flucuate. then as i was driving my speedo needle begins to fall up and down as i do 60 on the fwy. now my alarm will not arm itself, and my side turn signals do not work? my 7.5 amp fuse keeps blowing everytime i try to replace the back up radio fuse.. anyone kno whats wrong, i belive my original problem of my idle fluctuating is electrical because now everything else isnt working as well... please help!!!
Old Jan 18, 2006 | 05:41 AM
any strange dash warning lights?
Old Jan 18, 2006 | 07:39 AM
mssond's Avatar
mssond
Has the alternator been checked for over charging?
Old Jan 18, 2006 | 03:28 PM
94ccordEx's Avatar
94ccordEx
you think it could be an alternator problem? it all started with me gunning it up a hill, then i smelled something burning, and my radio and clock went out, but i get the strange idle bouncing, and now my speedo jumps.
Old Jan 18, 2006 | 03:58 PM
94ccordEx's Avatar
94ccordEx
my alarm doesnt arm anymore, my corner signals dont work anymore, my windsheild wiper dont work too. is there fuses for those things?
Old Jan 18, 2006 | 06:31 PM
strykernyc's Avatar
strykernyc
have u check the main relays ? when the main relays goes bad then usually the fuse keep blowing and the turning signal and other lights just go nuts.
make sure u check all the main relays and all the fuse. DO NOT I REPEAT DO NOT take it to the dealer.
Old Jan 18, 2006 | 10:30 PM
94ccordEx's Avatar
94ccordEx
how do you check/know when the main relays are bad? is taht why when i try to replace the radio clock fuse it keeps poping as soon as it goes in?
Old Jan 19, 2006 | 02:02 AM
mssond's Avatar
mssond
I have had an over charging alternator before, but it mainly made the dash lights go on and off, everything else was ok,
Old Jan 19, 2006 | 04:32 AM
how steep was this hill?
Oil shifts in the engine. By "gunning it", your chambers might not have been properly coated for something like that.
