honda brake pads
Old Jan 13, 2006 | 05:53 AM
TexasFlood's Avatar
TexasFlood
Default honda brake pads
I bought a set of Honda front pads from the dealer. ('02 accord lx 4 cyl.)
There is a small bag of graphite in the box.
Does anyone know where this goes?
Old Jan 13, 2006 | 08:31 AM
JimBlake's Avatar
JimBlake
Is it like anti-seize grease? Maybe it's for the back of the pads where they fit against the piston (inboard) or caliper (outboard). Also where the ends of the pad backing plate fit into the caliper bracket. Anti-squeak grease...
Old Jan 13, 2006 | 10:04 AM
accordhybrid's Avatar
accordhybrid
spread that grease all over the back of the pads and then press the metal shims on the brake pad and install into the caliper
Old Jan 14, 2006 | 03:05 PM
TexasFlood's Avatar
TexasFlood
Yep, it is grease. Looks like graphite powder in the bag. Guess I should have opened it before I posted. Like Red says on That 70's Show......"DUMB ASS"
Old Jan 22, 2006 | 04:16 PM
tireguy98's Avatar
tireguy98
when you are taking the caliper off make sure that you remove the slide pins from the caliper and clean them also. get a small packet of molly lube and lube the slides to ensure that you wont have any problems with uneaven pad wear down the road. just a little tip to save you the possibility of a problem down the road.
Old Jan 22, 2006 | 10:32 PM
wedley2's Avatar
wedley2
bboy Wesley West
yea, grease your calipers...i think mine are stuck because i already have heat marks on my rotors (fairly new, less than 1k on them)s
Old Jan 24, 2006 | 05:11 AM
jobrien's Avatar
jobrien
You don't have to use the grease, but it's a good idea if you do. Like everyone has already said, it goes between the pad and the metal shim that goes up against the pad before you mount it back into the caliper.
The pads oscillate in the caliper up against this shim and that's what can cause some squealling.
Old Jan 25, 2006 | 01:09 PM
b33rnut010's Avatar
b33rnut010
you should put it on the other side of the shims also, the side that comes in contact with the caliper
