Suspension Problems/Change Suggestions...
Old Jan 12, 2006 | 02:00 PM
khyzersoze's Avatar
khyzersoze
Default Suspension Problems/Change Suggestions...
History:
2001 Ex-V6 Coupe
Springs: H&R Sport
Shocks: Tokico Blue
Front Camber Kit: Something similar to this for the 98-2002 accords (http://www.specprod.com/PROD_DIR/C_P...d2=84800&cmd3=)
Rear Camber Kit: http://www.specprod.com/PROD_DIR/C_P...d2=67090&cmd3=
Issue:
I've had this setup for a while now and a couple years ago it was just fine. A year and a half ago I was driving around on stock rims, because I didnt' have time to get new tires for my car, and just recently put my rims with new tires back on last year. At which point I also had an alignment done, and everything was set up perfectly including the camber.
After a year, I'm starting to hear clanking noises in the front sometime, where I think my arm is hitting the fender well, where it didn't before.... and the insides of my front tires are way overworn then they should be for only having had them a year, maybe less.. while the rest of the tire is actually in pretty good shape. And by inside of the tires being worn.. it isn't the usual roughly 6 inch span with negative camber ..... but a specific 1 inch ring of tire that is bald on the inside of the tire. The rest of the tire still had pretty good tread left.
Possible Causes???:
Have I been driving on under-inflated tires? I didn't think they were under-inflated.
My springs are sagging more
My shocks are having issues and not holding up? (They don't seem to be leaking).
Other issue?
Possible Solutions:
Just go get coilovers and raise the car a little?
Replace springs?
Change the front camber kit with a better one?
Get new tires and make sure they're not under-inflated.
Anyone have any ideas on what might be happening, and solutions?
Thanks!
Old Jan 12, 2006 | 03:12 PM
jschmid's Avatar
jschmid
I'd get an alignment and see what the camber and toe is. Toe will eat tires faster than negative camber, and excessive NC and bad toe will really eat up tires. It could be that the camber kit is banging on the inner fender under suspension compression. That's common with the ball joint replacement type kits, but the link you posted appears to replace the whole arm. But something sounds out of wack.
Old Jan 12, 2006 | 03:34 PM
khyzersoze's Avatar
khyzersoze
The type of front camber kit I have replaces those ball joints (2) that the arm connects to the body with. Basically it pushes the arm out a little more, and right now, I think the top front edge of the arm is hitting the fender well.
I'm just wondering what is causing the excessive tire wear, because I drive like a granny, and previously before I even had a camber kit.... my tire wear was NEVER this bad. I even had a set of Pirelli P7000's for 2 years. Right now I have Falken ZE-512's. And the funny thing is... most of the tire tread is still good. It's just that inner 1 inch of the tire tread that is completely bald.
Old Jan 12, 2006 | 07:17 PM
jschmid's Avatar
jschmid
Incorrect toe my friend, incorrect toe.
In reality it's probably a combination of some bad toe and negative camber, that's why I said you should get an alignment to see what the settings are.
Old Jan 12, 2006 | 08:03 PM
khyzersoze's Avatar
khyzersoze
Thx man. I'll get it checked up.
So in short... the tires are pretty much unsalvageable right? I've gotta get 2 new front tires then.
