1994 Accord LX Drivers Door Trim Panel
Old Jan 9, 2006 | 11:17 PM
tomservo's Avatar
tomservo
Default 1994 Accord LX Drivers Door Trim Panel
I just removed the trim panel from the drivers door, and now I can't seem to get it back on. Somehow I just can't seem to get it seated properly. Any tips?
Old Jan 10, 2006 | 01:27 AM
waaBAAH's Avatar
waaBAAH
broken clips? idk
Old Jan 10, 2006 | 03:10 AM
burnrubber's Avatar
burnrubber
Nucking Futs
are you having trouble putting the door lock knob through it's hole on the door panel? if so make sure you pick the panel up and push it closer against the window, make sure the door lock is up, and put your fingers behind the panel and help guide it in. also check to see if any clips are worn out, if so replace them.
Old Jan 10, 2006 | 07:22 AM
tomservo's Avatar
tomservo
Yeah, I didn't have the door pushed in far enough for the top part to align correctly. Thanks.
