98 Accord remote does not open the driver door
Hi I have a 98 Accord 4 door sedan.
I sometimes have a problem with the driver's door not unlocking. Only three doors open instead of all 4 doors.
Can anyone tell me what the problem could be?
How to troubleshoot the problem?
Sometimes also when all the doors unlock it takes a few clicks of the remote to make them open and the battery in the remote is new.
Any ideas would be appreciated thanks
Ruben
Ruben
Originally Posted by rsalazar98
Which door switch are you refering to?
I have to open it manually with the key once the other three doors are open from the remote.
thanks
Ruben
thanks
Ruben
Yes I can open the drivers door with the door switch inside no problem.
It only fails with the remote. The drivers door does not open with the remote. The three doors open fine with the remote.
Is it still the actuator?
Ruben
Ruben
Originally Posted by mn__30
Mostly likely the problem is the door lock actuator. I replaced 3 actuators on my 99 Accord since I bought it.
Does the driver door lock open when you use the door switch ???
Originally Posted by ohhonda98
SO how much does one of those cost, because I am having th esame problem with my 98 Coupe. I hear that passanger side click/unlock but I do not hear a thing from the drivers side!
The part cost about $40, But the labor is what is going to get you.
