Help to remove front brake piston Accord 01
1) While changing the brake pads of my car, I notice the right side bushing (boot) of the piston is ripped and damage. I bought a new replacement but I have no idea how to remove the piston to change the boot? I guess I have to bleed the brake and remove the pressure applied to the piston then remove it but I want to get you guys opinion before I am doing it.
2) I normally do not bleed the brake before changing brake pads but I am not sure it's the correct procedure. I don't have any problem so far but it could just mean I am damn lucky. What's the correct procedure to change brake pads in ABS system - to bleed or not to bleed?
TIA
Lanny
TIA
Lanny
this wont answer your question, but you can always just disconnect the line going to the caliper and mess around the caliper w/o having to worry about pressure w/ the piston.
but yea, you'll still need to bleed the brakes after fixing the piston gasket/bushing thingie.
