'90 ex starting roughness
Old Dec 11, 2005 | 08:44 AM
meangreen90's Avatar
meangreen90
Default '90 ex starting roughness
everytime i crank up my accord ex cold it starts real rough and bucks. anyone know any possible causes for this. what is that starting air valve at the drivers end of the intake plenum? any info appreciated. thanks
Old Dec 11, 2005 | 11:30 AM
Splatch's Avatar
Splatch
bad as hatch
i would be suspisious of the starting air valve you suggested
Old Dec 13, 2005 | 02:24 PM
schnellboot's Avatar
schnellboot
CB7 extrordinaire
Is there quite a bit of blue smoke upon startup when its running rough, and if so does it end when the engine smooths out? If that's the case then pull your #2 spark plug and see if the spark plug tube is filled with oil. There is an oil passage less than .5" from the #2 plug tube. If it is filled with oil, you'll need to replace your spark plug tube seals. Alternately, if #2 is dry then its your valve guides that are shot.
Old Dec 13, 2005 | 05:02 PM
meangreen90
ya but where do you buy a starting air valve?? no one sells them? not really interested in going to honda for it. i just put a valve cover gasket set on it when i adjusted the valves about a year ago and they're dry b/c i checke dthem not too long ago.
