low-high beam conversion
Old Nov 28, 2005 | 09:33 PM
DUNK_Performanc's Avatar
DUNK_Performanc
ThAiLaNd-Land of Smiles
Default Its simple
The bulb will fit with wiff just a little etchin on the ears and a 9005 plug in
Old Nov 28, 2005 | 09:35 PM
yeap
don't forget to take the 9006's rubber ring too
Old Nov 28, 2005 | 09:38 PM
DUNK_Performanc
Default Not exactlly
the box says "CAUTION" off road use onlee, anyway they are great for driving at night with just PK lamps and headlights. Also the advantage is that they nearlly blind small animals and deter them from crossing the road.
Old Nov 28, 2005 | 09:46 PM
DarkSideAccord's Avatar
DarkSideAccord
Chidori-chan :love:
let him run the 100W bulbs a lil longer and he'll wish he listened to us.... 100W bulbs will melt ur wiring harness eventually, esp if u use it a lot.... once it's melted, it's a bitch to remove... just my 2 cents
Old Nov 28, 2005 | 10:07 PM
DUNK_Performanc
Default I think itll be fine but thanks
It'll be fine, there is a small vent, If it will burn any wire it will burn the single power wire coming from the bulb itself, i doubt it damagingthe wire, the wires arent like thin peices of thread, there like 10 guage factory wiring going to the fog lamps.I think yu may hab issues if they are aftermarket fogs and wiring tho.
Old Nov 28, 2005 | 10:33 PM
wedley2's Avatar
wedley2
bboy Wesley West
output is good but it aint concentrated...
Old Nov 28, 2005 | 10:35 PM
p_mcnaught's Avatar
p_mcnaught
I melted 2 sets or harnesses in my car, The wires dont burn up! The plastic housing warps and the plugs start to slide out of the housing and arch on the connectors!
Old Nov 28, 2005 | 10:41 PM
DUNK_Performanc
Default sorry to hear about that
thats too bad, But H3 bulbs have no plastic on them. It consists of the glass bulb, light element and metal fixture holding the bulb. Its not plastic like 9000 series bulbs
Old Nov 29, 2005 | 04:05 AM
Dzaccord's Avatar
Dzaccord
I did a 9006 to 9005 coversion with a set of sylvania cool blues back in the day.
The light output was excellent
I agree. I have that exact setup now until I switch to true HID.
Old Nov 29, 2005 | 05:34 AM
Yeap, can't say we didn't mention it.
When you melt a harness, you either:
a. actually melt the bulb to the connector
b. melt your headlight housing's lens
c. cause an electrical fire
