Spark Plug Removal
Old Nov 23, 2005 | 06:32 AM
Jon02Accord's Avatar
Jon02Accord
Default Spark Plug Removal
i am getting close to the time when i need to replace my plugs. do i need to do anything special to get the plug covers off? they look different than the style i see on most cars. do they just pull off like regular wires?
thanks!
Old Nov 23, 2005 | 06:54 AM
I think you can just pop them off.
NOTE:
Clearly label your plug wires. You don't want to screw up the firing order.
Old Nov 23, 2005 | 07:24 AM
Jon02Accord
thanks
Old Nov 24, 2005 | 09:00 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
yup just pop them off and use a 16mm socket if i remember right to remove the plugs
Old Nov 26, 2005 | 09:01 PM
FallenAngelHIM's Avatar
FallenAngelHIM
do them one at a time...PLEASE!!!! don't try to be cool and take them apart all at once, you might mess up the order.
on another note advanced auto parts sell this "kit" that has the tune up tools for about 8 dollars. it comes with the big wrench, two extensions, a swivel head, and then 3 different size "spark plug" heads for you to do your spark plugs. i got that, and it's awesome. i think it's by mech-power. it's great if you don't have the tools!
Old Nov 26, 2005 | 10:51 PM
DUNK_Performanc's Avatar
DUNK_Performanc
ThAiLaNd-Land of Smiles
Default Twist and pull
Twist a little and then pull, i am sure we have all had our share of the boots of the spark plug wires staying lodged in the tube or sumthin other similar.A 5/8 spark plug socket will grab the plugs fine. make sure its a spark plug socket, they have a rubber insert in the socket that holds the plug in the socket making removal and instilation in the plug tube a sinch.
Old Nov 27, 2005 | 04:55 AM
Jon02Accord
cool, bc my research shows that advance has the honda/ngk plugs cheaper than HandA.
Old Nov 27, 2005 | 07:30 AM
jschmid's Avatar
jschmid
If you have an I4 I don't see how you could really "mess up the order" because the length of each oem plug wire is different.
Old Nov 27, 2005 | 08:05 AM
DUNK_Performanc
Default Onlee if replaing the cap
Onlee if yu are replacing teh distributor cap be cautious of where they go, usually i just remove the cap with the wires still attached to it and go from there, , install a new cap and then wires 1 by 1
