weird exhaust noise
Old Nov 12, 2005 | 01:25 PM
TinTin's Avatar
TinTin
Hong Kong
Default weird exhaust noise
hey
im a pretty new car owner (since this past may) and i haven't really had a problem with the car at all, which is a
1995 Honda Accord LX Sedan
anyways...recently about 2 months ago this weird noise starts to come out when i drive
it sounds like as if there is a hole in the exhaust, but not as severe, just kinda sounds like the engine is straining
however this sound ONLY occurs during 2000 rpm...at all other revs it sounds fine
and it doesn't seem to have affected the performance of the car at all...except when the passengers faces go :ugh: when they hear it
i asked my dad over the phone, who isn't a car expert but has had 30 years of driving experience, he said it is possible that it is due to the weather, since it started turning cold and all...im in Buffalo, New York btw
my guess is that its something wrong with the exhaust...
so what do you guys think...is this a common problem among 95 accords? any solution (without replacing the whole exhaust?)
Old Nov 14, 2005 | 04:47 AM
TinTin's Avatar
TinTin
Hong Kong
no help? :hs:
Old Nov 14, 2005 | 04:54 AM
what are you hearing? an metallic rattle? does the engine bog down and almost die?
Old Nov 14, 2005 | 07:54 AM
TinTin's Avatar
TinTin
Hong Kong
yea, a rattle
but i do notice that...when it rattles it suffers a *slight* loss of power and smoothness in acceleration
it only occurs at 2000rpm...
everything else drives fine
Old Nov 14, 2005 | 09:09 AM
xpragmaticx's Avatar
xpragmaticx
chipedge
I would guess that the rattle is your CAT or Muffler against their clamps. At every rpm your car has a unique frequency. It's probably just at 2000 rpms that the right frequency is hit to vibrate whatever is loose. I don't know why you would lose horsepower though.
Old Nov 14, 2005 | 09:21 AM
auto or stick?
2000rpms might be around a shift point.
Old Nov 14, 2005 | 10:52 AM
TinTin's Avatar
TinTin
Hong Kong
and that as the next person said, the "loss of pweor" is probably just due to shift point
any solutions? i haven't really done anything hands on with the car other than replacing the brake light h:
Old Nov 15, 2005 | 08:47 AM
ssunny76g's Avatar
ssunny76g
Hey Tin Tin...looks like there is a TSB from Honda on this problem...I own a 95 EX coupe and I have the same issue....check out the attached file that I pulled off another threa in this forum.....hope this helps.
File Type: pdf
Old Nov 15, 2005 | 05:02 PM
TinTin's Avatar
TinTin
Hong Kong
hey thanks for the help!
anyone can guesstimate the cost?
Old May 9, 2006 | 10:57 AM
reech-around's Avatar
reech-around
RIP Woong.
damn im a victim of this too. happens at exactly 1800rpm :doh:
any cheap DIY remedies for this?
