valve adjustment questions
Old Nov 11, 2005 | 06:10 PM
Digiti123's Avatar
Digiti123
Default valve adjustment questions
What are the symptoms that a 1998 Accord LX four cylinder needs a valve adjustment? What is the prescribed interval? How much shop time is involved and what is the average cost. Thanks.
Old Nov 11, 2005 | 09:46 PM
DuffMan983's Avatar
DuffMan983
valve adjustment really isnt all that hard to do by yourself. but if you're not too mechanically inclined then just take it to a honda dealership. i wouldn't trust a regular shop with it. I actually did it myself on my 01' and it only took an hour start to finish. If I had to ballpark a cost I would say youre looking around $150 to get it done at a shop.
oh, here's how to tell if you need a valve adjustment.... when your engine is cold, start up your car. open up the hood and put your ear up to the valve cover. if you hear a prevailant ticking sound coming from under the valve cover, that's your valves. no matter what, you can always hear your valve train moving, but if there is a loud ticking then your valve lash needs adjustment. I believe honda's service manual requires valve adjustment every 50k, but im not exactly sure.
Old Nov 11, 2005 | 10:06 PM
wedley2's Avatar
wedley2
bboy Wesley West
yep, the camry is in dire need of one...the valve train is probably gone from all the wear sicne we dont take care of it h:
Old Nov 12, 2005 | 05:46 AM
Digiti123's Avatar
Digiti123
I called Honda and I was quoted $129 . My symptoms are a noisier engine at idle and upon acceleration, a roughness in the idle, and a slight vibration that can be felt in the floor when pressing down on the gas. The car has 83,000 miles and timing belt was done at dealer two years ago, a regular tuneup was done in May of this year. Does this fit the picture? Also I do not want to put myself at the mercy of the Honda dealer re: package service deals. I want ala carte if possible. Thanks.
Old Nov 12, 2005 | 06:35 AM
wedley2's Avatar
wedley2
bboy Wesley West
rear motor mount might contribute to vibration?
it might be best to do the balve adjustment yourself because 130 is a bit up there.
