94 Accord EX starter problem
Old Oct 30, 2005 | 12:42 PM
Hillrat's Avatar
Hillrat
Hillrat
Default 94 Accord EX starter problem
Having a starting problem with my 94 Accord Ex. It will start about one in every five to ten tries. The other times I get a single click. Tried replacing the battery but to no avail. Doesn't seem to be a battery problem cause the batt is holding a charge fine.
Also one time I got a single click then no power anywhere. No dash lights, headlights, nothing. When I tried jumping it, it wanted to start by itself, no keys in the ignition. Buddy of mine said it could be a problem with the ground but I can't trace the ground far enough to check it out. Ant ideas would be appreciated. I am dead broke and would like to resolve this as cheaply as possible.
Thanks for any help.
Old Oct 30, 2005 | 01:08 PM
OHS's Avatar
OHS
Banned
Default Good news for you......
This problem is buried in the ABC's, that is Another Busted Car!
Old Oct 30, 2005 | 01:31 PM
Hillrat's Avatar
Hillrat
Hillrat
Thanks for the info OHS. I have tried cleaning the connections on both the battery and the starter. The positive connection on the starter looks A-1 as does the ground. The boot on the ground is a little cracked but the crimp itself looks good.
The battery terminals were pretty oxidized and I have cleaned then up as well. The only thing I can't access is the other end of the ground for the starter. Where is it?
After doing all this the car started three or four times without a problem then back to the click. Still sarts about every five or so tries. A couple of times there was a "tock" after the "tick" when I released the key, but not again since.
Old Oct 30, 2005 | 01:42 PM
bonestock's Avatar
bonestock
Originally Posted by Hillrat
Having a starting problem with my 94 Accord Ex. I am dead broke and would like to resolve this as cheaply as possible.
is it an automatic? if so i have a perfectly working starter off a 94 EX auto that i can sell for cheap to check if its your starter.
now when you changed the battery does the new battery still hold a charge? if not it maybe the alternator.
Old Oct 30, 2005 | 01:47 PM
JL95AccorD's Avatar
JL95AccorD
I would have said it's just the starter going back and getting stuck. But I just figure if the battery is good, and the car won't start, that it must be the starter not working properly.
Old Oct 30, 2005 | 02:22 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
definitely a loose connection somewhere, as you mention the lights and everything else quitting one time. The ground on the motor is mounted to a plate underneath the starter... not super easy to get to.
Old Oct 30, 2005 | 02:37 PM
OHS's Avatar
OHS
Banned
Default Starter
Another busted car :lmfao:
Old Oct 30, 2005 | 02:43 PM
Hillrat's Avatar
Hillrat
Hillrat
thanks all. I think I might have to break down and actually take it to someone to be fixed. I am at a lack of tools to top it all off. Thanks for the suggestions
Old Oct 30, 2005 | 03:07 PM
OHS's Avatar
OHS
Banned
Good
