When to get a camber kit
Old Oct 26, 2005 | 10:20 AM
PunkAssKidThe1s's Avatar
PunkAssKidThe1s
Team Babu
Default When to get a camber kit
I'm looking at dropping my car somewhere between 1.5" and 2.25" (trying to decide which springs to get) and am on 17x7's (going into winter, it'll be all-season 15's) and next summer, looking to go up to 18".
At what point is it worth getting a camber kit?
Old Oct 26, 2005 | 11:36 AM
Misa's Avatar
Misa
Pic Whore
if your camber is out of spec, and the alignment place can't correct it... then you need a camber kit.
Old Oct 26, 2005 | 06:16 PM
jschmid's Avatar
jschmid
You can do the washer trick on the rear since you have a 97. Search for the info.
The more drop you get, the more correction you'll need. With a 1.5, might not any...2.25, count on it.
For the front, see what people have good luck with. My 6th gen has pretty high tolerances up front...I have about 1.75-2.0 up front, and it's still in the specs. Not sure how 5th gens differ.
Old Oct 27, 2005 | 12:26 AM
zidek_accord's Avatar
zidek_accord
i have no gap on 18s and i sure as hell needed and got one. ingalls extreme is the stuff
Old Oct 29, 2005 | 09:12 PM
hype8912's Avatar
hype8912
Dr. Klaw
You can put the camber kit on when you install the springs jut set the camber to a nominal setting. Like someone said you can save some money and do the washer trick on the rear. Just wait like 2 or 3 weeks before getting an alignment. You need to allow the springs to completely settle before adjusting the alignment.
Old Oct 29, 2005 | 10:01 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
At the same time that you do suspension mods. Otherwise your tires will suffer some uneven wear.
