91 accord problem
Old Oct 16, 2005 | 05:02 PM
f22a accord's Avatar
f22a accord
Default 91 accord problem
can any one help me with this on my 91 accord it shakes when i start it up and when i step on the gas and let go it deccelerates and when i turn on the a/c it turn off. please help me.
Old Oct 16, 2005 | 09:57 PM
meredithf's Avatar
meredithf
Originally Posted by f22a accord
...and when i step on the gas and let go it deccelerates ...(
isnt that what is supposed to happen?
these symptoms are kinda vague, might want to clarify the problem(s) a bit.
Old Oct 16, 2005 | 10:03 PM
wedley2's Avatar
wedley2
bboy Wesley West
im thinking, when he hits the gas...it bogs pretty bad and when a/c is on it stalls.
Old Oct 17, 2005 | 07:34 AM
f22a accord
Default 91 accord
when i start my car up it shake bad and when i accelerate and let go it deccelerates from 4 rpms to in the middle of 1 and 0 some times it even goes all the way to o and comes back up slow and if i try to turn on the a/c the car turns off.. so if you please help.
Old Oct 17, 2005 | 07:36 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
I'm not trying to be a dick but next time you have a problem, attention to grammar, punctuation, and good detail will get you a lot more answers I spent too much time trying to decipher what you are saying.
Try 1/3 can seafoam in an intake vacuum tube to clean out carbon deposits then come back and tell us if you're having the problem.
Old Oct 18, 2005 | 03:03 PM
OHS's Avatar
OHS
Banned
I'd start by checking the ABC's ie Alternator? Battery? Connections? Disconected wires? Error from previous service work? Fuel system (fuel level/pressure/filter/pump)? Grounds (ecu related)? Has the timing been checked? Ignition components good? Just started this or been slowly deteriorating? Knocking noises with problem? Loose timing belt? Mainly happen cold, hot or both? No airflow (air filter)? Oil level good? Poorly maintained? Quick changes in idle or power? Rode hard and put away wet? Sometimes it happens and sometimes it dont? Timing belt old? Unmodified or modified? Violent shaking and shudder? Water pump bearing good? Xamine these again and re-check if in doubt, Y do I say this because these problems you describe generally occur with Zero or poor service.
Your problem is probably buried somewhere in the basics. If the basics are OK, than suspect ECU issues. The Check light coming on may not indicate a problem with the ECU or sensor, but rather may be detecting an improper running condition with the vehicle and is saying SERVICE ME!!!!!
Reprint permission requested on my ABC's thing there. Hope it helps??
Good luck, work safely.
Ozarks Honda Specialist is dedicated to being the very best.
