94 Accord 5sp Manual transmission Shift Cable
Not certain on the off chance that this is the spot to post this or on the other hand assuming its even been discussed however figured I would surrender individuals a heads. Certain individuals say the shift links of an understanding 90-93 are something similar and fit the 94-97. This isn't thoroughly evident. The set accompany 2 links for the individuals who dont know. The shift link itself fits yet it does re-position the shift stick about an inch and a half back from its unique position, meaning you will have it nearer to you than typical. The select link doesn't work by any stretch of the imagination. If you somehow happened to utilize this link it moves the shift stick almost totally to the traveler side of the vehicle and you can't move as a result of the middle concsole. In the event that you anticipate utilizing a mix of the 90-93 shift link with a 94-97 select link it very well may be finished by cutting the boot keeping the 2 links intact and afterward utilizing a similar boot with some RTV gasket or concrete paste. This did some incredible things. Despite the fact that it feels abnormal for me to move this a lot nearer to me, it carries the shifter nearer to me and gives me better toss opportunity and velocities.
192.168.100.1 192.168.1.1
