3 problems.......
Old Oct 12, 2005 | 07:11 PM
Sonny's Avatar
Sonny
Default 3 problems.......
I have 3 problems with my h22, its a 00 and i have an oil leak somewhere on the driver's side. I don't know wher so if you can give me some insight that would be greatly appreciated. Secondly, I'm getting a code that says vtec pressure switch (code 22) I checked for continuity on the switch and it's fine so I know the switch works, I'm not sure if it's the wiring or ecu. Lastly, My cooling fan doesn't turn on, the fan itself is working b/c i jumped it and it turns on, what should I look for in order for it to work properly. Thankx for the help
