Cigarette Lighter - No Power
Old Oct 10, 2005 | 06:01 PM
INeed597's Avatar
INeed597
Default Cigarette Lighter - No Power
Help. I'm trying to power my XM Roady 2 from the cigarette lighter. Here's what happens. The minute I plug it in the cigarette adapter sends no power. When I remove the XM plug I measure the cigarette adapter and I have power. I tried the phone charger and lighter and both do the same. I then connected a Radio Shack adapter and measured the power at the other end. Sure enough I had power. The minute I attach a load the power stops. The devices work fine in my other vehicle. What gives?
'94 Honda Accord
Thanks
Old Oct 10, 2005 | 06:27 PM
shonnv's Avatar
shonnv
7th Gen Coupe V6
Does you cig Lighter throws power at all, I mean does the lighter works? if it does work at all?
Old Oct 10, 2005 | 08:41 PM
stereo's Avatar
stereo
check the fuse ...
Old Oct 11, 2005 | 06:27 AM
INeed597's Avatar
INeed597
Default POwer
Thanks for the quick replies. Yes the cigarette lighter has power (checked by meter) before and after inserting the adapters. But not while the adapter is in. I thought the adapter might be shorting the socket but I connected an adapter and checked the end of the leads and had power. The minute it detects a load either the phone, XM, or lighter itself, it cuts off power. Fuse is ok.
Old Oct 11, 2005 | 07:29 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Are you sure the fuse inside the XM adapter isn't blown?
Old Oct 12, 2005 | 09:18 AM
INeed597's Avatar
INeed597
Default No Blown Fuse
No. The adapters all work fine in my other car. I just downloaded the service manual to try to troubleshoot this.
