Help Check engine light
Old Oct 7, 2005 | 01:16 PM
Smittyslxcoupe's Avatar
Smittyslxcoupe
Default Help Check engine light
Check engine light comes on, cant rev it pass 3200rpms idels rough, D4 light flashes at me!!!!!! HELP Burns alot of fule...oil type substance comes out exhaust when reved high
Old Oct 7, 2005 | 02:25 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
You can look up check engine codes yourself, but the description of your problem is very vague. It's impossible to diagnose a problem when you write two sentences and we can't see it ourselves...what is it, where is it coming from, when does it happen, what car do you have, etc.
Old Oct 7, 2005 | 03:55 PM
shonnv's Avatar
shonnv
7th Gen Coupe V6
The D4 light flashes cause your transmission has detected a malfunction.
Old Oct 7, 2005 | 04:04 PM
Smittyslxcoupe
its a 95 Honda Accord lx 2dr f22 basically what happend was one day i got a spoon chip for my old ecu i had worked on it my self and fucked it up and when it fucked up i turned on the car and the check engine light comes on it idels rough and you can rev it or make it shift past 3200Rpms.. and sucks gas like no tomorrow so i said fuck it, i got the sport ecu you from spoon racing then and it still has the same problem...the instructions say that the enige is getting ahead of it self and that i need to retard the timing be even doing that isnt going to fix everything. I mean it happens right when i turn on the car... then a few seconds later the d4 light flahses and stays like that...i disconncected the battery and everything before installed it and still no luck
Old Oct 7, 2005 | 04:12 PM
98CoupeV6's Avatar
98CoupeV6
Is your car heavily modified?
Did you get the 94-95 ecu like we told you or did you install the one you had?
Old Oct 7, 2005 | 04:17 PM
Smittyslxcoupe
Default The new ecu
This is the Ecu that i had got for my car
http://cgi.ebay.com/ebaymotors/SPOON...spagenameZWDVW
Once i pluged this in I stil had the same problems
Old Oct 7, 2005 | 04:19 PM
Smittyslxcoupe
The only thing i have done to the car is an intake and a ebay torque chip which splices into the IAT sensor which i never had a problem before
Old Oct 7, 2005 | 04:21 PM
98CoupeV6's Avatar
98CoupeV6
"SPOON custom ignition and fuel curves ADDED"
There ya go...enjoy your custom mapping since apparently you don't trust the engineering Honda did.
Old Oct 7, 2005 | 04:26 PM
Smittyslxcoupe
Default ok...
ok so what the Fu*k is that suppose to mean i know it has new fuel maps and ignition so what the hell am i suppose to do.
Old Oct 7, 2005 | 04:29 PM
98CoupeV6's Avatar
98CoupeV6
Realize that you wasted $150 on a poorly engineered ECU that's probably not meant for stock engines and put your old ECU back in?
When you do things like change the ignition timing and fuel maps you have to compensate by doing things like modifying the camshafts or adding FI...it's not as simple as just squirting more fuel into the cylinders and expecting to gain 20 horsepower, unfortuanetly.
