1996 Honda Accord TRANSMISSION problem
Old Oct 5, 2005 | 09:59 AM
xretrogirlx's Avatar
xretrogirlx
Default 1996 Honda Accord TRANSMISSION problem
I have a 1996 Honda Accord Coupe with a 2000 VTEC Engine installed...the transmission recently started screwing up...it works fine up until 3rd gear but will not shift into 4th gear. After about 24 hours of not driving it and the car resting, I can start the car up and it will shift into 4th gear but after that it wont. Is this a speed sensor problem? Or does the transmission need to be replaced? Nothing is wrong electronically to my knowledge, at least nothing is showing on the dash that there is.
NOTE: I am a girl, so everytime I go to a mechanic they tell me it needs all of this and that and I really dont want to get scammed. So any guidance is appreciated!
Thanks!!
Old Oct 5, 2005 | 10:23 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Are you sure it has an F23 in it?
Are there any CELs? It's impossible to diagnose anything over the internet without DTCs.
Old Oct 5, 2005 | 10:49 AM
TrackMasterz's Avatar
TrackMasterz
i just had to smile at this post....why put a 2k accord engine/tranny in a 96 accord. It's a risk because of the crappy transmissions on the 6th gen. accords.
Old Oct 5, 2005 | 07:44 PM
stereo's Avatar
stereo
I bet they bolted the F23 motor to the F22 trans. anyways have you checked your trans fluid? if it's low you might get shifting problems but i'm suprised that you didn't get a check engine or a flashing D4 light.
Old Oct 5, 2005 | 09:11 PM
bEaNaShOnDa95's Avatar
bEaNaShOnDa95
*~~~> APBT
my honda was shifting down but it was some coil in the engine i have a 95 but after that my honda works fine
