98 Accord Won't Start...Ignition Coil???
Old Oct 4, 2005 | 02:21 PM
jefe's Avatar
jefe
Default 98 Accord Won't Start...Ignition Coil???
Hi everyone. I am new to the site.
My wife's 98 Honda Accord EX 4cyl auto. won't start. It was occasionally not starting before I tried to fix it, now it won't start at all!
I replaced the rotor and dist. cover. The ignition coil looks "beat up", but there is a spark when the ignition is turned on. (The dealer tested it and said it was "out of spec" but might work nonetheless)
Any suggestions or ideas?
Old Oct 4, 2005 | 02:23 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
main relay?
Old Oct 4, 2005 | 02:27 PM
jefe's Avatar
jefe
I guess I am suspicious of the coil since it looks worn and before I did anything inside the dist. the car would at least start, albeit sometimes reluctantly. I just hate to blow $70 on a new coil and still have the car not starting after already putting $35 in for the cover and rotor...
Old Oct 5, 2005 | 07:49 AM
JimBlake's Avatar
JimBlake
A bad main relay won't run the fuel pump. Turn key on, don't turn all the way to 'start'. The fuel pump should run for a second, listen for it. It's not very loud, so turn off radio & blowers. Maybe have someone listen under the trunk while you try it.
Old Oct 5, 2005 | 09:20 AM
wedley2's Avatar
wedley2
bboy Wesley West
a "beat up" igntion coil? :lmao:
id check the main relay first and worry about the igntion coil later.
Old Oct 5, 2005 | 09:21 AM
98CoupeV6's Avatar
98CoupeV6
Also the pump will only make 2 clicks instead of the normal 3. I posted that trick in some other thread.
Old Oct 9, 2005 | 10:20 AM
jefe's Avatar
jefe
Yep. It was the ignition coil. Thanks all!
