Do I need a new battery??
Old Oct 2, 2005 | 04:13 PM
JL95AccorD's Avatar
JL95AccorD
Default Do I need a new battery??
Last night I went out for a "spirited" drive after the streets dried up (rained all day) and I noticed at one point that when the car was at around 5K rpm, my battery light was kinda trying to light up very dimly. The higher the rpms the brighter it would get, but it would turn off once it went below like 4K. I was guessing that the battery is probably about to die. Is that most like the culprite? (BTW no other lights on the dash lighting up, just the battery.)
Also, I was looking into getting an optima red top battery... worth it? aproximately how much can I expect one to go for at a regulay shop?
Is there any other battery I should look into, and for how much?
Old Oct 2, 2005 | 08:22 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
The same thing used to happen to me and it turned out to be my alternator so do a voltage test first.
Optima red tops are the best, I've never heard anything bad about them.
Old Oct 2, 2005 | 09:56 PM
wedley2's Avatar
wedley2
bboy Wesley West
hah, just buy a battery and put it in the trunk, that way when the batt. does go out...change it on the spot and go on your merry way!
Old Oct 3, 2005 | 04:36 AM
JL95AccorD's Avatar
JL95AccorD
It's strange. It had done the same thing like about 3 weeks ago, but those have been the only two times I've seen it do that. I had also been thinking of getting a high output alternator, so I guess I'll have to test the battery and alt. and see which one is going to get replaced first. Any cons to high output alts.? Recomended brand or sites to buy from would be helpful too.
Can someone tell me the difference between the optima red tops and yellow tops?
Old Oct 3, 2005 | 08:17 AM
98CoupeV6's Avatar
98CoupeV6
Yeah that really sounds like a grounding problem to me man...grounds get corroded very easily.
Old Oct 3, 2005 | 08:29 AM
JL95AccorD's Avatar
JL95AccorD
hmmm... that sounds interesting too. You mean the battery ground connected to the chasis?
Old Oct 3, 2005 | 08:31 AM
98CoupeV6's Avatar
98CoupeV6
Yeah battery or alternator. I have no idea where they are on 5th gens.
Old Nov 4, 2005 | 08:48 AM
JL95AccorD's Avatar
JL95AccorD
update:
I still havent tested the alt, but I went and got an optima red top
Awesome battery
system hits harder, and engine running better. (lower rpms while doing certain MPH)
Will have to wait and take her out for a "spirited" drive this weekend and see what happens with the battery light.
Still considering the high output alt. Gonna have to do some research.
