93 Honda Accord front rotors
Old Sep 30, 2005 | 06:42 PM
Raf99's Avatar
Raf99
Default 93 Honda Accord front rotors
Couldn't find a posting for this so thought I'd ask...
1993 Honda Accord EX. I bought new brakes, calipers, hoses, rotors, but have did it all except the rotors and the hoses. I hear I'm in for a battle when I try to get the rotors off...
Heated on ?
Removing bearings ?
Something I can do on my own ? I'm guessing its not going to pop off easy.
Old Sep 30, 2005 | 06:45 PM
honda guy's Avatar
honda guy
yeah they suck. Make sure you get new bearings to. They will probably be ruined when you do get the rotors off.
Old Sep 30, 2005 | 06:46 PM
ItsaHonda's Avatar
ItsaHonda
Not sure about the 4th gens (90-93) but the 5th gen Accords had pressed on rotors. You'll need to find a local shop that can remove them with the proper equipment. I don't believe the 4th gens had pressed on rotors (I believe it was only the 5th gen Accord that Honda experimented with them) but I could be wrong. Good luck.
Old Sep 30, 2005 | 06:54 PM
Raf99's Avatar
Raf99
Ya... they're pressed on
Dam. will be a while before they're on then.
Old Sep 30, 2005 | 07:21 PM
booner's Avatar
booner
sup man try this:
http://www.cb7tuner.com/vbb/showthread.php?t=26122
Follow that and you should be fine, i did mine by myself using that guide. If you have any other questions regarding it ask now while i still remeber, i did mine about two weeks ago. Oh yea you dont need to press on anything, your supposed to but just tighten those star shaped bolt like crazy and you should be fine. Just dont forget the cotter pins!
Old Sep 30, 2005 | 09:09 PM
Raf99's Avatar
Raf99
oh wow. Def. will read, thank you.
Old Sep 30, 2005 | 10:05 PM
wedley2's Avatar
wedley2
bboy Wesley West
i wrote that
def. easy with the right tools...but time consuming on your first try.
Old Sep 30, 2005 | 10:43 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Originally Posted by booner
That same diy (wedley wrote it) is on HAN :doh: Plus it's in the faq. No need to link to other sites
Old Sep 30, 2005 | 10:46 PM
booner's Avatar
booner
oh my bad, didn't know it was on here h:
Old Sep 30, 2005 | 10:49 PM
98CoupeV6's Avatar
98CoupeV6
Hm, actually it isn't on here. My bad. I guess I've just seen the link so many times I got confused h: wedley, post that thing in the rotor/hub removal FAQ thread plz
