97 accord engine idleing up and down
Old Sep 26, 2005 | 06:42 PM
mrherrera's Avatar
mrherrera
Default 97 accord engine idleing up and down
i have a 97 accord ex,vtec, and the engine is idleing up and down,can someone tell what to look for to get to the problem,what can be causing this?the CEL is not on.
Old Sep 26, 2005 | 06:51 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
do a search for uneven idle or rough idle, we go over this a lot. could be egr, iacv, spark plugs, etc.
Old Sep 27, 2005 | 03:07 AM
shadetreemech's Avatar
shadetreemech
I had a Mitsubishi Eclipse and it would idle up and down after you started it. The problem was the idle sensor.
Old Sep 28, 2005 | 10:00 PM
neonknight0311's Avatar
neonknight0311
Yes, it is called hunting, something is amiss with your sensors. Get a Chiltons or Helms book, it describes several error conditions or symptoms and their possible causes. You can check the easy stuff before you go to a dealer or mechanic. Good luck.
