spark plugs for accord?
Old Sep 23, 2005 | 10:45 PM
thefullbug's Avatar
thefullbug
Default spark plugs for accord?
I just bought a 2002 accord sedan.
What type of spark plugs should i use in it?
Also where is the fuel filter on this car?
Old Sep 24, 2005 | 09:43 PM
shonnv's Avatar
shonnv
7th Gen Coupe V6
:doh: :repost:
Old Sep 25, 2005 | 02:06 PM
xxzeppelin5xx's Avatar
xxzeppelin5xx
fuel filter is in tank....use any NGK plugs, just pay a visit to advance auto
Old Sep 25, 2005 | 03:18 PM
shonnv's Avatar
shonnv
7th Gen Coupe V6
You dont need to service the fuel filter and for the spark plugs go with NGK or Denso(Copper for Performance and Platinums for durability)
Old Oct 22, 2005 | 06:52 AM
buffalobill's Avatar
buffalobill
Is there a need to switch to either 'hotter' or 'cooler' heat-range spark plugs following the install of a header, cat-back and a short ram intake, or will the originals still be okay? And should the spark plugs' gap also remain the same as the original specs? Engine is an F23A (4 cyl Vtec) in an '02 Accord. Thanks.
Old Oct 22, 2005 | 01:44 PM
Thooks's Avatar
Thooks
President-2008
You need to use the original plugs. Pull one out, cover the hole with a rag, and trot down to the parts store.
Here's another good idea- Buy a tube of Anti-seize compound and put a little on the threads. You might appreciate it in another 60k miles.
Did I mention use NGK plugs?
Old Oct 22, 2005 | 06:32 PM
DUNK_Performanc's Avatar
DUNK_Performanc
ThAiLaNd-Land of Smiles
Default Non servicable
newer model cars have non servicable filter, , teh strainer on these models(98-up) accords and other imports have non servicable units, tehre is no longer and external fuel filter, the redesign of the fuel pump strainer is all thats needed now.being all teh new units are not just fuel pumps but the whole sending unit and pump it incorporates 2 strainers, one external of the tank unit and one incased with the fuel pump in the body of the sending unit eleminating the external servicable fuel filter.
Old Oct 22, 2005 | 07:06 PM
neonknight0311's Avatar
neonknight0311
The word I get is to stick to stock plugs and wires, no noticable performance gains (Dyno) from the conversion. You might get better insulation properties with thicker gauge wires though.
