Need help with Hi Flow catalytic
Old Sep 16, 2005 | 05:14 PM
JDM ACCORD's Avatar
JDM ACCORD
Default Need help with Hi Flow catalytic
I bought a Hi flow catalytic from Ebay and it said it was for a Honda Accord 96, but when I was taking off the original I noticed it has an O2 sensor and the new one doesn't what do I do? Do I leave the cable disconnected? Is there going to be a problem or something? Please Help.
Old Sep 16, 2005 | 06:12 PM
shivers's Avatar
shivers
Moderator Alumni
The best thing you could do, is return the high flow cat or sell it. Unless your stock one is toast or you're pushing huge HP/TQ, a high flow cat isn't really going to help you.
2005 s2000
Old Sep 16, 2005 | 06:52 PM
JDM ACCORD's Avatar
JDM ACCORD
I dont think I can return it back, and about selling it I doubt it, I was really hoping to install it but Im not sure if I should since the O2 hole is not on the converter, any body have any suggestions?
Old Sep 16, 2005 | 08:49 PM
georgie's Avatar
georgie
find a nut that will thread onto the O2 sensor and try to mount it to the same place on the new cat and drill a hole and have the nut welded over the hole. you cna also take it to an exhaust shop and have them weld a bung into place
Old Sep 16, 2005 | 11:02 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Someone sells kits for this I think to fool the O2 sensor.
Old Sep 17, 2005 | 08:30 PM
stereo's Avatar
stereo
it sounds like that guy sold you a 94-95 cat. because the 96-97 cat. has the o2 bung in it so if it was stated for a 96-97 accord then he misrepresented the item. and should take it back!
Old Sep 18, 2005 | 02:12 PM
cconfusionn's Avatar
cconfusionn
That was exactly what happened to my best buddy last year. The 94-95 accord have a collector which the sensor is located at. The cat u bought is for the 94 and 95. the 96-97 accord don't have a collector therefore the sensor is on the cat itself. you can find someone with a 94-95 accord and sell to them or drill a whole on ur cat and put the sensor on. My friend went to a muffler shop and they did the service for $70 which i thought was extremely crazy. He bought a cat for $30. He could have used that $70 + $30 to get a custom pipe done all the way to the muffler from the converter. I have a 94 accord. u can give it to me hbahahaha
