front end noise =/
Old Sep 14, 2005 | 06:53 AM
StRaIgHtUp7's Avatar
StRaIgHtUp7
boobies!!!
Default front end noise =/
i lowered my car about a month and a half ago and for some reason now i have a slight popping noise from my front end...it happens when i go from a dead stop and while turning on a bumpy road or surface...ne thoughts?
Old Sep 14, 2005 | 07:01 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Does it happen when you go over bumps?
Old Sep 14, 2005 | 08:13 AM
StRaIgHtUp7
boobies!!!
not really...my driveway isnt paved n while im backin into my driveway and turning i can hear it...its not loud though...i almost have to turn my radio all da way down to hear it
Old Sep 14, 2005 | 08:54 AM
98CoupeV6's Avatar
98CoupeV6
Well it probably isn't blown struts then. That usually happens when you lower and don't replace them.
Check your lower ball joints and sway bar end links for damage.
Old Sep 14, 2005 | 08:55 AM
StRaIgHtUp7
boobies!!!
my setup is tein s.tech springs...kyb gr2 shocks...n spc camber kit
Old Sep 14, 2005 | 09:21 AM
98CoupeV6's Avatar
98CoupeV6
Like I said, go inspect your suspension components carefully for damage. It's usually a busted endlink that makes noise.
Old Sep 14, 2005 | 12:28 PM
StRaIgHtUp7
boobies!!!
thanks buddy!
Old Sep 14, 2005 | 08:44 PM
FireGuySith's Avatar
FireGuySith
My GF had a similar problem with her RX300. It turned out to be some warn out bushings in the struts. whenever she hit a small bump or if the car suspension dipped down, it would knock on the top plate of the strut. i'm not sure whether that is the problem for your but it might be worth checking out.
Good luck dude.
Old Sep 14, 2005 | 10:28 PM
wedley2's Avatar
wedley2
bboy Wesley West
yea, try tightening the top bolt that holds the strut assembly together. the camry would knock hella hard and when we blasted the two nuts down with an impact wrench, it was all good.
Old Sep 15, 2005 | 08:32 AM
StRaIgHtUp7
boobies!!!
its not a loud clunking noise...its kinda like pluckin a rubber band only louder...n its only apparent at very low speeds...like when i take off from a dead stop...*shrugs*
