CL front brake conversion on 96 honda accord V6
I have an understanding of what needs to be done for the conversion, but one thing I cannot visualize is that bolts and screws that I will need.
Here is an exploded diagram of an accord's front brakes.
Here is an exploded diagram of the acura CL's front brakes
To keep things simple I will not talk about brake pads. I plan on ordering part number 4 from the accord diagram and parts 25 and 26 from the acura CL diagram.
Could someone tell me what bolts I need. Looking at the Acura CL diagram bolt 27 attaches the hub(25) to the bearing (4.) What do I use to attach the rotor (26)? The holes in the rotor look small like they might take allen bolts or screws. Even if I order all the bolts listed it looks like none will fit in the rotor. I thought about ordering screws that are used to attach the rear disc. They are listed as "screw-flat (6x14).
Do I still need bolt 23 to attach the hub to the steering knuckle or will bolt 27 take care of that? I want to order new bolts in case the old hardware becomes damaged.
Here's a list of what you need
94-97 Accord wheel bearings
98-99 CL 2.3 hubs (it comes with studs already)
98-99 CL 2.3 rotors of your choice
94-97 Accord brake pads
You will not need any new bolts, you can just re-use all of your accord bolts.
If you have any questions please feel free to contact me.
Accordhybrid
Accordhybrid
Since mine is a V6, I need the 3.0 parts correct? Thanks for your help accord hybrid. I saw your previous post on teh subject in 2003 but still had a few questions and didn't want to revive such an old thread.
Originally Posted by Big Chaze
really???
Once you do the conversion,.. they wont be pressed in anymore??
Luckily they changed this with the 6th gens so I don't have to deal with it.
Has anyone actually done the brake conversion on the 5th gen V6. I have been checking at accordinglydone.com and it seems to be uncharted territory. If i could go without my car for a decent period of time I would be a guinea pig, but I don't think that would be possible.
