Need Help for cyclinder 1 Misfired
Old Aug 15, 2005 | 06:55 AM
mdvd's Avatar
mdvd
Default Need Help for cyclinder 1 Misfired
96 Accord EX---Engine lights on.. and have check with 2 code detectors, both saying misfired in cylinder 1..( and only cylinder 1)
After reset for serveral time, I found every time the light come one at around 2300- 2700 rpm ( no matter what gear or shift up or down; if I stay in 2300-2700 rpm band for about 5 sec..the light will on ) .....feel a little bit lack of power..( maybe I saw the light and I feel it has some problem), A mechanic told me that it should be the distributor rather than the injectors, as he test the pressure and fuel feed of the car are ok... is he right? need some advice...
Old Aug 15, 2005 | 07:17 AM
flyromeo3's Avatar
flyromeo3
well i had that problem on my 02 once. I got the check engine light...blah ....blah....at the end it was the spark plug cable that kept popping in and out of the cylinder........Got a new one problem never happend again.
how new are your spark plug cables and spark plugs.?
Old Aug 15, 2005 | 07:21 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
https://www.honda-acura.net/forums/s...33#post2451533
Massive trouble shooting lies ahead.
