Vibration problem
Old Aug 10, 2005 | 09:17 AM
kth981332003's Avatar
kth981332003
Default Vibration problem
Hi all,
Please help..My accord is vibrating when it is at 45-60 mph. The steering wheel seem fine. But the gas pedal and the front bottom seem raddled/vibrated strong. What is wrong? This is a 1994 accord EX / 5 sp
Old Aug 10, 2005 | 09:20 AM
sibiryk's Avatar
sibiryk
rear tires need to be balanced?
Old Aug 10, 2005 | 09:31 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Originally Posted by kth981332003
Hi all,
Please explain more in depth...does this happen at all throttle angles and all gears? Hit any nasty curbs or potholes lately? When did this start? Any recent changes/maintenance you've made to your car?
For now my vote goes to an unbalanced or unaligned front wheel, or a bent front rim.
Old Aug 10, 2005 | 10:33 AM
syclone's Avatar
syclone
agree..
but you can start with the most obvious too.. check to make sure all your lug nuts are tightened..
Old Aug 10, 2005 | 11:29 AM
kth981332003
Sibiryk, thanks and I will check on the rear tires. But why in the rear not the front?
Syclone, thank you so much for the advises. Will work on it when I get off from work.
98CoupeV6, basically when i shifted from 3rd to 4th and at 45-60 mph speed.
Old Aug 10, 2005 | 11:31 AM
kth981332003
The problem just started recently. I don't recalled hit a curb. And haven't had a wheel alignment for awhile.
Old Aug 10, 2005 | 12:09 PM
syclone's Avatar
syclone
usually if it's in the front, you would feel the vibration in the steering wheel too..
another thing i forgot to mention is to check your tires.. is it worn and near time for replacement? somtimes a bubble will form on the tire and cause the vibration.
Old Aug 10, 2005 | 12:12 PM
sibiryk's Avatar
sibiryk
... why in the rear not the front?
You didn't mention vibration on a steering wheel. When front wheel is unbalanced it passes vibration on steering.
Old Aug 10, 2005 | 04:01 PM
syclone's Avatar
syclone
Old Aug 10, 2005 | 06:57 PM
sibiryk's Avatar
sibiryk
When I started to write my answer you didn't post yours.
So when I was done I found that you answered on my question already.
It is so unfair to answer questions directed to others. :wtc:
I hope this is the answer you were looking for.
