PCV valve and IAC valve
Old Jul 20, 2005 | 07:21 PM
Bubblez's Avatar
Bubblez
Default PCV valve and IAC valve
I need help........Where do I find the PCV valve and the IAC valve in a 95 Accord I am having idle problems when I stop at at a light and my car idles really low and will sometimes stall.
Old Jul 21, 2005 | 02:12 PM
Accord96's Avatar
Accord96
Lurker
I'd invest in either a Hayne's or Helm's manual (relative to your make and model) if you're having problems with this.
Old Jul 21, 2005 | 03:26 PM
wedley2's Avatar
wedley2
bboy Wesley West
IAC is attached to the intake mani by two 12mm bolts and the pcv valve is attached to the valve cover. it looks like a L shaped plastic thing.
Old Jul 21, 2005 | 05:08 PM
jmg's Avatar
jmg
I have a similar problem, but my car never stalls, it is a 96 Accord. I just had it in the shop for a tuneup and timing belt and they didnt mention a PCV valve...
Old Jul 21, 2005 | 10:17 PM
wedley2's Avatar
wedley2
bboy Wesley West
well, the part is 3 dollars and you can install it in the kragen parking lot. all you need is a pair of pliers...
Old Jul 22, 2005 | 06:36 AM
kmcaprice14's Avatar
kmcaprice14
Its also a good idea to check the spark plug channels by removing the spark plug caps. If there is oil in there you may have spark plug tube seal issues... this can cause idle issues. I replaced mine and it idles much better now. Just a thought....
Old Jul 22, 2005 | 06:06 PM
jmg's Avatar
jmg
I boght a new pcv valve, how easy is it to replace?
Old Jul 22, 2005 | 06:17 PM
Bubblez's Avatar
Bubblez
thankx for the help..... Why do you think my cars idle only acts up and the car stalls while I am running the ac? I know I am in 115-120 degree weather but it has never done this before...95 Accord
Old Jul 23, 2005 | 06:39 AM
jmg's Avatar
jmg
Is there a trick to get the PCV valve to come off of the hose that it is connected too? I cant get mine to come off. ANd yes I do have the clamp off.
