Help with '96 Transaxle Fluid Change!
Old Jul 20, 2005 | 03:17 PM
01ACCORD's Avatar
01ACCORD
Default Help with '96 Transaxle Fluid Change!
Okay, item 1 is the fill, item 2 is the drain. What are 3 and 4? I removed 3 and it looked like transaxle fluid (and smelled like it) drained a few drops. What are these plugs for? Some kind of maintenance window?
Also, is there and easy way to get fuid back in #1?
Old Jul 20, 2005 | 06:20 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Are you sure 1 is the fill? As far as I knew, all Hondas had innocuous looking little bolts on the top of the transmission housing for the fill. Good question about 3 and 4, I've never seen those.
Old Jul 20, 2005 | 06:40 PM
01ACCORD's Avatar
01ACCORD
This is a manual trans. The autos do have a cap on top.
Old Jul 21, 2005 | 08:38 AM
01ACCORD's Avatar
01ACCORD
UPDATE!
From my trusted mechanic at AAMCO:
#3 & #4 are for the interlock pins for 5th gear and reverse. DO NOT REMOVE! YOU MAY HAVE SOMETHING DROP IN THE TRANS!!!!!!!
Of course I removed #3 as I mentioned, but nothing was moved, and it was promptly replaced. Test drive proved that the Trans is okay, but with a nice fresh bath of fluid.
BTW, this '96 now has 161K on it, and I'm replacing the front Rotors for the first time...not too bad :-)
Old Jul 21, 2005 | 10:18 PM
wedley2's Avatar
wedley2
bboy Wesley West
is it hub over rotor assembly? i just did those also h:
